Jump to: navigation, search
RaceCapturePro scripting
Contents
Logger Functions
startLogging()
Start logging data to a new logfile, using the current configuration
stopLogging()
Stops a current logging session, if active
setLed(led,state)
Sets a LED to the specified state
  • led : 0-2
  • state : 0=off; 1=on
state isSDCardPresent()
Indicates if an SD Card is inserted
  • state : 1=SD card is present; 0=SD card is missing
state isSDCardWritable()
Indicates if the SD card is writable
  • state : 1=SD card is writable; 0=SD card is write protected
flashLoggerConfig()
Writes the current logger configuration to flash memory
DAC functions
value getAnalog(channel)
Gets the voltage for the specified analog channel
  • channel : 0 - 7
  • value : voltage
value getAnalogRaw(channel)
Gets the raw ADC value for the specified analog channel
  • channel : 0 - 7
  • value : raw ADC value
setAnalogLabel(channel,label,units)
Sets the label for the specified analog channel
  • channel : 0 - 7
  • label : channel label
  • units : channel units label
label,units getAnalogLabel(channel)
Gets the labels for the specified analog channel
  • channel : 0 - 7
setAnalogSampleRate(channel,rate)
Sets the sample rate for the specified analog channel
  • channel : 0 - 7
  • rate : sample rate
rate getAnalogSampleRate(channel)
Gets the sample rate for the specified analog channel
  • channel : 0 - 7
setAnalogScaling(channel,scaling)
Sets the scaling value for the specified analog channel
  • channel : 0 - 7
  • scaling : the decimal scaling value for the specified analog channel. Logged values are multiplied by this scaling value.
scaling getAnalogScaling(channel)
Get the scaling value for the specified analog channel
  • channel : 0 - 7
PWM / DAC functions
setAnalogOut(channel,voltage)
Sets the analog output voltage for the specified PWM/DAC channel
  • channel : 0 - 3
  • voltage : 0.00 - 5.00
Sets the duty cycle percentage for the specified PWM/DAC channel
setPwmDutyCycle(channel,duty)
  • channel : 0 - 3
  • duty : duty cycle 0-100
setPwmDutyCycleRaw(channel,duty)
Sets the raw duty cycle value for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmPeriod(channel,period)
Sets the period for the specified PWM channel
  • channel : 0 - 3
  • period : <TODO define this>
setPwmPeriodRaw(channel,period)
Sets the raw period value for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmClockFrequency(frequency)
Sets the clock frequency for the PWM/DAC generator
  • frequency : the base PWM frequency (10 - 2000)
frequency getPwmClockFrequency()
Gets the clock frequency for the PWM/DAC generator
setPwmLabel(channel,label)
Sets the label for the specified PWM/DAC channel
  • channel : 0 - 3
label getPwmLabel()
Gets the label for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmSampleRate(channel,rate)
Sets the sample rate for the specified PWM/DAC channel
  • channel : 0 - 3
label getPwmSampleRate(channel)
Gets the sample rate for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmOutputConfig(channel,config)
Sets the configuration for the specified PWM/DAC channel
  • channel : 0 - 3
  • config : 0=analog; 1=frequency
config getPwmOutputConfig(channel)
Gets the configuration for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmLoggingConfig(channel,config)
Sets the Logging configuration for the specified PWM/DAC channel
  • channel : 0 - 3
  • config : 0=Log PWM Period; 1=Log PWM Duty Cycle; 2=Log DAC volts
config getPwmLoggingConfig(channel)
Gets the Logging configuration for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmStartupDutyCycle(channel,duty)
Sets the startup PWM duty cycle for the specified PWM/DAC channel
  • channel : 0 - 3
  • duty : duty cycle 0 - 100
channel getPwmStartupDutyCycle(duty)
Gets the startup duty cycle for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmStartupPeriod(channel,period)
Sets the startup period for the specified PWM/DAC channel
  • channel : 0 - 3
  • period : period 1 - 2000
period getPwmStartupPeriod(channel)
Gets the startup period for the specified PWM/DAC channel
  • channel : 0 - 3
setPwmVoltageScaling(channel,scaling)
Sets the voltage scaling for the specified PWM/DAC channel. Used when in DAC mode
  • channel : 0 - 3
  • scaling : voltage scaling
scaling getPwmVoltageScaling(channel)
Gets the voltage scaling for the specified PWM/DAC channel. Used when in DAC mode
  • channel : 0 - 3
Timer functions
rpm getTimerRpm(channel)
Gets the calculated RPM for the specified timer channel
  • channel : 0 - 2
  • rpm : value, in RPM
period getTimerPeriodMs(channel)
Gets the calculated period, in mS, for the specified timer channel
  • channel : 0 - 2
  • period : value, in mS
period getTimerPeriodUsec(channel)
Gets the calculated period, in uS, for the specified timer channel
  • channel : 0 - 2
  • period : value, in uS
freq getTimerFrequency(channel)
Gets the calculated frequency, in Hz, for the specified timer channel
  • channel : 0 - 2
  • freq : value, in Hz
value getTimerRaw(channel)
Gets the raw value for the specified timer channel
  • channel : 0 - 2
  • value : raw timer count value
count getTimerCount(channel)
Gets the count value for the specified timer channel, when configured as a slow timer
  • channel : 0 - 2
  • count : slow timer counts
resetTimerCount(channel)
Resets the count value for the timer channel, when configured as a slow timer
  • channel : 0 - 2
setTimerLabel(channel,label,units)
Sets the labels for the the specified timer channel
  • channel : timer channel 0 - 2
  • units : units label
label,units getTimerLabel(channel)
Gets the labels for the the specified timer channel
setTimerSampleRate(channel)
Sets the sample rate for the specified timer channel
rate getTimerSampleRate(channel)
Gets the sample rate for the specified timer channel
setTimerConfig(channel,config)
Sets the configuration for the specified timer channel
  • configuration : 0 = RPM; 1 = frequency(Hz) ; 2 = period(uS) ; 3 = period(mS)
config getTimerConfig(channel)
Gets the configuration for the specified timer channel
setTimerPulsePerRevolution(channel,value)
Sets the pulse-per-revolution for the specified timer channel.
  • value' : the number of pulses representing a complete revolution of a rotational device (crankshaft, wheel, etc)
value getTimerPulsePerRevolution(channel)
Gets the pulse-per-revolution for the specified timer channel.
  • value : the number of pulses representing a complete revolution of a rotational device (crankshaft, wheel, etc)
setTimerDivider(channel,divider)
Sets the clock divider for the specified timer channel.
  • divider : 2 = Master Clock / 2; 8 = Master Clock / 8; 32 = Master Clock / 32; 128 = Master Clock / 128; 1024 = Master Clock / 1024
divider getTimerDivider(channel)
Gets the clock divider for the specified timer channel.
calculateTimerScaling(channel)
Recalculates the timer scaling, from the current timer divider and pulse per revolution values for the specified channel.
value getTimerScaling(channel)
Gets the current calculated scaling value for the specified timer channel
  • value : the current scaling value
GPIO functions
state getGpio(port)
Provides the state of the specified GPIO port.
  • port : 0 - 2
  • state : 0=low; 1=high
setGpio(port,state)
Sets a GPIO port to the specified state
  • port : 0 - 2
  • state : 0=low;1=high
setGpioLabel(port,label)
Sets the label for the specified GPIO port
  • port : GPIO port 0 - 2
  • label : label
label getGpioLabel(port)
Gets the label for the specified GPIO port
  • label : label
setGpioSampleRate(port,rate)
Sets the sample rate for the specified GPIO port
rate getGpioSampleRate(port)
config setGpioConfig(port,config)
Sets the configuration of the specified GPIO port
  • config : 0 = configure as input; 1 = configure as output
config getGpioConfig(port)
Gets the configuration of the specified GPIO port
state getButton()
Returns the status of the front panel button
  • state 1=button pressed; 0=button not pressed
Accelerometer functions
value readAccel(channel)
TODO document Yaw Sensor Reads the specified Accelerometer channel
  • channel : 0-3
  • value : The accelerometer value, in G
value readAccelRaw(channel)
  • channel : 0-3
  • value : The raw accelerometer value
setAccelInstalled(installed)
Sets the installed state of the accelerometer module
  • installed : 1 = installed; 0 = not installed
installed getAccelInstalled()
Gets the installed state of the accelerometer module
setAccelLabel(channel,label)
Sets the label for the specified accelerometer channel
  • channel : accerometer channel 0 - 3
label getAccelLabel(channel)
Gets the label for the specified accelerometer channel
setAccelSampleRate(channel,rate)
Sets the sample rate for the specified accelerometer channel
rate getAccelSampleRate(channel)
Gets the sample rate for the specified accelerometer channel
setAccelIdleSampleRate(channel,rate)
Sets the sample rate for the specified accelerometer channel when not logging
rate getAccelIdleSampleRate(channel)
Gets the sample rate for the specified accelerometer channel when not logging
setAccelConfig(channel,config)
Sets the configuration for the specified accelerometer channel
  • config : 0 = disabled ; 1 = normal orientation; 2 = inverted orientation
config getAccelConfig(channel)
Gets the configuration for the specified accelerometer channel
setAccelChannel(physical,logical)
Maps the logical channel to the specified physical accelerometer channel
  • physical : Physical accelerometer port : 0 = X; 1 = Y; 2 = Z; 3 = Yaw
  • logical : Logical accelerometer port : 0 = X; 1 = Y; 2 = Z; 3 = Yaw
logical getAccelChannel(physical)
Gets the logical mapping for the specified physical accelerometer channel
setAccelZeroValue(channel,value)
Sets the zero or resting value for the specified accelerometer channel
  • channel : accelerometer channel 0 - 3
  • value : zero value
value getAccelZeroValue(channel)
Gets the zero or resting value for the specified accelerometer channel
calibrateAccelZero()
Perform automatic zero calibration of all accelerometer channels
GPS functions
TODO- consider collapsing this into a lat,long = GetGPSLocation() function
value getGPSLatitude()
Gets the current GPS Latitude
  • value : GPS Latitude in decimal degrees
value getGPSLongitude()
Gets the current GPS Longitude
  • value : GPS Longitude in decimal degrees
value getGPSVelocity()
Gets the current GPS velocity
  • value : GPS velocity in Kph
value getGPSQuality()
Gets the current GPS Quality indicator TODO find out the values
  • value : the GPS quality indicator
value getGPSTime()
Gets the current GPS time of day
  • value : the current GPS time of day, in UTC decimal format
value getGPSSecondsSinceMidnight()
Gets the current GPS time of day, in seconds since midnight
  • value : decimal seconds since midnight
value getTimeDiff(from,to)
Calculates the period between the specified time, within a 24 hour period. Accounts for midnight transition.
  • to : to time, in seconds since midnight
  • value : time difference, in seconds since midnight
value getTimeSince(time)
Calculates period between the current GPS time and the specified time, within a 24 hour period. Accounts for midnight transition.
  • time : the from time, in seconds since midnight
  • value : time since, in seconds since midnight
setGPSInstalled(installed)
Sets the installation state of the GPS feature
  • installed : 1 = GPS installed; 0 = GPS not installed
installed getGPSInstalled()
Gets the installation state of the GPS feature
  • installed : 1 = GPS nstalled; 0 = GPS not installed
setGPSQualityLabel(label)
Sets the label for the GPS quality field
  • label : label
label getGPSQualityLabel()
Gets the label for the GPS quality field
  • label : label
setGPSSatsLabel(label)
Sets the label for the GPS stats field
  • label : label
label getGPSSatsLabel()
  • label : label
setGPSLatitudeLabel(label)
Sets the label for the GPS latitude field
  • label : label
label getGPSLatitudeLabel()
Gets the label for the GPS latitude field
  • label : label
setGPSLongitudeLabel(label)
Sets the label for the GPS Longitude field
  • label : label
label getGPSLongitudeLabel()
Gets the label for the GPS Longitude field
  • label : label
setGPSTimeLabel(label)
Sets the label for the GPS time field
  • label : label
label getGPSTimeLabel()
Gets the label for the GPS time field
  • label : label
setGPSVelocityLabel(label)
Sets the GPS velocity label
  • label : label
label getGPSVelocityLabel()
Gets the GPS velocity label
  • label : label
setGPSPositionSampleRate(rate)
Sets the sample rate for the GPS position
rate getGPSPositionSampleRate()
Gets the sample rate for the GPS position
setGPSVelocitySampleRate(rate)
Sets the sample rate for the GPS velocity
rate getGPSVelocitySampleRate()
Gets the sample rate for the GPS velocity
setGPSTimeSampleRate(rate)
Sets the sample rate for the GPS time
getGPSTimeSampleRate()
Gets the sample rate for the GPS time
Serial Port functions
data readSerial(port)
Reads a line from the specified serial port
  • port : 0 - 1
  • data : The read string
writeSerial(port,data)
Writes a string to the specified serial port
  • port : 0 - 1
  • data : data to write
Supported Sample Rates
  • 0 - Sampling disabled
  • 1 - 1Hz
  • 5 - 5Hz
  • 10 - 10Hz
  • 20 - 20Hz
  • 30 - 30Hz
  • 50 - 50Hz
  • 100 - 100Hz
