MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
list=usercontribs (uc)
(main | query | usercontribs)
Get all edits by a user.
Parameters:
uclimit
The maximum number of contributions to return.
Type: integer or max
The value must be between 1 and 500.
Default: 10
ucstart
The start timestamp to return from, i.e. revisions before this timestamp.
Type: timestamp (allowed formats)
ucend
The end timestamp to return to, i.e. revisions after this timestamp.
uccontinue
When more results are available, use this to continue.
ucuser
The users to retrieve contributions for. Cannot be used with ucuserids or ucuserprefix.
Type: list of users, by any of user name, IP and interwiki name (e.g. "prefix>ExampleName")
Separate values with | or alternative.
Maximum number of values is 50 (500 for clients that are allowed higher limits).
ucuserids
The user IDs to retrieve contributions for. Cannot be used with ucuser or ucuserprefix.
Type: list of integers
ucuserprefix
Retrieve contributions for all users whose names begin with this value. Cannot be used with ucuser or ucuserids.
ucdir
In which direction to enumerate:
newer
List oldest first. Note: ucstart has to be before ucend.
older
List newest first (default). Note: ucstart has to be later than ucend.
One of the following values: newer, older
Default: older
ucnamespace
Only list contributions in these namespaces.
Values (separate with | or alternative): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
To specify all values, use *.
ucprop
Include additional pieces of information:
ids
Adds the page ID and revision ID.
title
Adds the title and namespace ID of the page.
timestamp
Adds the timestamp of the edit.
comment
Adds the comment of the edit. If the comment has been revision deleted, a commenthidden property will be returned.
parsedcomment
Adds the parsed comment of the edit. If the comment has been revision deleted, a commenthidden property will be returned.
size
Adds the new size of the edit.
sizediff
Adds the size delta of the edit against its parent.
flags
Adds flags of the edit.
patrolled
Tags patrolled edits.
tags
Lists tags for the edit.
Values (separate with | or alternative): comment, flags, ids, parsedcomment, patrolled, size, sizediff, tags, timestamp, title
Default: ids|title|timestamp|comment|size|flags
ucshow
Show only items that meet these criteria, e.g. non minor edits only: ucshow=!minor.
If ucshow=patrolled or ucshow=!patrolled is set, revisions older than $wgRCMaxAge (7776000 seconds) won't be shown.
Values (separate with | or alternative): !autopatrolled, !minor, !new, !patrolled, !top, autopatrolled, minor, new, patrolled, top
uctag
Only list revisions tagged with this tag.
uctoponly
Deprecated.
Only list changes which are the latest revision.
Type: boolean (details)
Examples:
Show contributions of user Example.
api.php?action=query&list=usercontribs&ucuser=Example [open in sandbox]
Show contributions from all IP addresses with prefix 192.0.2..
api.php?action=query&list=usercontribs&ucuserprefix=192.0.2. [open in sandbox]
