BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
Connecting to the first Pulse/RPM input of the system
- Connect the sensor pigtail to Port P2 of the 4 way splitter, then connect the splitter to the "A" branch of the 8-4 splitter
- Configure the first channel at the top of the list for Pulse/RPM Sensors in the RaceCapture app
TPS
- 0.62 volts at 0% throttle
- 4.64 volts at 100%
Engine Temperature
In research
Should be similar to E30
Fuel Level
Note: This assumes the factory gauge is still connected.
Mapping in the analog channel
- 0.2v = 0 (empty)
- 1.33v = 25 (1/4)
- 2.2v = 50 (half)
- 2.95v = 75 (3/4)
- 3.53v = 100 (full)
Brakes
- Tap the Blue/Red wire coming out of the brake light switch on the back of the brake pedal. Wire this to a digital GPIO input of RaceCapture. Note: Must use a 10k Ohm resistor between the GPIO input and brake light wire.
- Can be helpful to know when the driver actually applies the brakes for data analysis of the driver. This gives you a simple yes/no of whether the driver is on the brakes. Lets you know exactly when they applied the brakes. Use this in conjunction with TPS to see how much time they are 'coasting', or how long it takes them to transition from throttle to brakes and vice versa.
Oil Pressure
Available Sensors:
- RPM
- EngineTemp
- TPS
- IAT (needs to be converted to F)
- WheelSpeed (needs to be converted to MPH)
- MAF
- EngineLoad
- FuelFlowRate
- Timing
Assumes:
- Pin 10 on radio connector
setTickRate(10) --10Hz
--virtual channels
--global constants
first = 4.20
second = 2.49
third = 1.66
fourth = 1.24
fifth = 1.00
final = 3.46
tirediameter = 24.7
--global variables
rpm = 0
rpm_diff = 0
speed = 0
function updateSpeedDiff()
rpm_diff = getTimerRpm(1)
function updateGear()
rpm = getTimerRpm(0)
local gearErr = 0.15
local gear = 0
if speed > 2 then
ratio = rpm/(rpm_diff*final)
if ((first - ratio)^2) < (gearErr^2) then gear = 1 end
if ((third - ratio)^2) < (gearErr^2) then gear = 3 end
if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end
setChannel(gear_id, gear)
updateSpeedDiff()
updateGear()
