BMW E46 CAN
Required parts
Plug and play harness system
Use the Power + CAN pigtail to supply power + data to the RaceCapture system:
See our Harness Specifications for the cable pinout
Estimated Time
2-3 hours, depending on level of wiring experience. The most time consuming part is splicing the CAN, power and ground wires into the cable.
CAN wires
- Yellow/Red = CAN+ (high)
- Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
| Connection | BMW | Power + CAN pigtail |
| +12v | Yellow-Red (OBD-II connector) | Red |
| Ground | Brown (OBD-II connector) | Black |
| CAN High | Yellow/Red | Green |
| CAN Low | Yellow/Brown | White |
Splice power and ground wires
Configure RaceCapture/Pro
Set Baud Rate
E46 CAN bus Preset
Verifying real-time data
Legacy RaceCapture systems with RJ45
DIY Cable
- Crimp tool
- Wire cutter
- Wire stripper
- Philipps screwdriver
- Multimeter
- 22-26 gauge wire
- RJ 45 (Ethernet) cable, ~6ft
- Shrink tubing (optional, electrical tape will work too, but not look as nice)
- Posi-tap connectors (2) - Do *not* cut the CAN wires during this installation, use wire taps (Posi-taps work very well)
- Butt connectors (2) for 22 gauge wire
CAN Bus connection
- Orange: CAN1 High
- Green/white: CAN1 Low
- Brown: Power
- Orange/white: Ground
Use the following diagram:
Additional resources
- http://aimsportsystems.com.au/download/ecu/stock/bmw/BMW_Mini_100_eng.pdf - AIM docs for e46 M3 CAN codes
- http://www.diyelectriccar.com/forums/showthread.php/my-can-bus-gauge-solution-bmw-84882.html
- http://www.beisansystems.com/misc/SEIMENS_MS_420_ENGINE_CONTROL_SYSTEM.pdf
- http://www.bmwtech.ru/pdf/e46/ST034/2%20Driver%20Information%20Internet-1.pdf
- http://www.gadgetgangster.com/news/54-new-projects/556-the-car-kracker.html
- http://www.reslers.de/IBUS/index.html
- http://www.bimmerforums.com/forum/showthread.php?1887229-E46-Can-bus-project
- http://forum.e46fanatics.com/showpost.php?p=15754605&postcount=5
