Button-bolt-on
The Button Bolt-On is a modular accessory designed to enhance the functionality of the ESP32-CAN-X2 development board. It integrates tactile push buttons and RGB LEDs for intuitive user interaction and feedback.
Key Features
Following are the features of 2 main components TS-1002S-04326C and WS2812 (2020 package) that are used in the Button bolt-on board.
  • Four tactile switches with a 6x6 mm footprint and 4.3 mm actuator height, offering reliable operation and minimal accidental presses.
  • Eight WS2812B 2020 RGB LEDs are strategically positioned around the buttons to provide clear visual feedback for user actions or system states.
Primary Purpose
  • Facilitates CAN-based messaging and local device control.
  • Enhances user experience with interactive lighting and button functions.
Applications
Button bolt-on consists of just a button and an LED so it makes user input functionality simple and efficient. Following are some of the real-world scenarios in which button bolt-ons can fit in perfectly.
Automotive
  • Driver selection (e.g., using buttons to identify which driver is using the car).
  • Adjust ECU tuning with a press of a button.
Home Automation
  • Use buttons to control smart appliances.
  • Indicate device states with customizable LED lighting patterns.
Industrial Use Cases
  • Trigger remote devices like pumps or fans.
  • Use LED signals to display system statuses or warnings
Getting Started
Assembly Instructions
  • Solder two 20-pin headers SV1 and SV2 to the Button Bolt-on PCB. These headers are available separately from a variety of sources (male/female) Amazon | Ebay
  • Ensure secure connections between the Bolt-on board and ESP32-CAN-X2 as per the following hardware connection
Hardware Connections
The following are the hardware connections for the Button Bolt-On and the respective ESP32 GPIOs from the ESP32-CAN-X2 board
The Following are the ESP32 GPIOs from the ESP32-CAN-X2 board to be used on the button bolt-on
SV1 Pins ESP32 GPIO Purpose
7 GPIO14 Connect to DIN of U1 (WS2812)
8 GPIO21 Connect to Push button S1
9 GPIO47 Connect to Push button S2
10 GPIO48 Connect to Push button S3
14 GPIO38 Connect to Push button S4
Required Tools and Materials
  • Button Bolt-On board.
  • ESP32-CAN-X2 development board.
  • Soldering iron (for assembling headers, if not pre-soldered).
  • USB cable Type-C for programming the ESP32.
Working
Working of the button bolt-on is simple as mentioned below for both button and LEDs
  • Each button can be configured to send unique CAN messages when pressed as well as periodically
  • RGB LEDs can provide dynamic feedback based on:
    • Button states (e.g., green for "on," red for "off").
    • Incoming CAN messages (e.g., flash when a message is received).
    • System diagnostics or statuses.
Project Examples
Project 1: Remote Device Toggle
Description:Use the Bolt-On to send CAN messages to toggle a remote device.
Implementation Steps:
  • Connect the ESP32-CAN-X2 and button bolt-on on top of each other through the connector SV1 and SV2 in the correct configuration.
  • Program the ESP32-CAN-X2 board to send a CAN message with the specific data (e.g., "Turn Light On"). based on the button bolt-on input through the S1, S2, S3, and S4 push buttons.
  • Program the ESP32-CAN-X2 to use the RGB LEDs on the button bolt-on to flash green on successful transmission and red on unsuccessful transmission of the CAN messages.
Project 2: Driver Selection System
Description: Configure buttons to assign driver profiles in a vehicle.
  • Map each button to a driver ID (e.g., Driver A = Button 1).
  • Use the LEDs to display the selected driver's ID with a specific color pattern.
  • Button Status / Driver profiles can be sent periodically or on event bases through CAN bus and remotely so some servers as well.
Project 3: Status Indicator
Description: Display system health or warnings using the RGB LEDs.
  • Program the LEDs to show green for normal, yellow for warning, and red for critical conditions.
  • Update LED states based on incoming CAN messages.
  • Reset the LED states via buttons as well.
Demo Code
The demo code for the button bolt-on can be found in the following GitHub repo in which the button states are periodically sent over the CAN bus as well as when the button is pressed. Demo Code
