Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
CAN bus harness components
Dual CAN splitter
M8-6P male to dual M8-4P female splits CAN1/CAN2 into individual CAN1 and CAN2 connections.
Dual CAN interconnect
Powered dual CAN hub
CAN extension
M8-4P male to M8-4P female cable extends a CAN bus network. Available in 0.5, 1, 2, 3, and 4 meter lengths.
CAN splitter
Inline CAN terminator
M8-4P male to M8-4P female inline 120 ohm CAN terminator - place one near end of the CAN bus network to ensure signal integrity.
Power CAN pigtail
M8-4P male to pigtail for connecting custom device to the Plug and Play cabling system, or for powering a RaceCapture or PodiumConnect system. 2 meter length.
| Pin | Color | Connection |
| 1 | White | CAN low |
| 2 | Red | 9-24v / 1A (~12W) |
| 3 | Green | CAN high |
| 4 | Black | Ground |
CAN+power for device
M8-4P female to pigtail for a custom-wired non Plug and Play connection to one of our CAN bus enabled devices such as TireX, AnalogX2, or ShiftX3
8 channel extension
Male to Female M12 12P cable extends 8 analog or digital channels. Available in 1 or 2 meter lengths.
8 to 4 channel splitter
M12-12P male to dual M8-8P female connector splits 8 analog or digital channels into dual 4 channel connections.
- Connections (Analog mode)
- Connections (Digital mode)
- RPM/Timer Channels 1-4 are connected to the 'A' branch
- GPIO channels 1-4 are connected to the 'B' branch
8 channel pigtail
M12-12P 0.3 meter male pigtail breaks out 8 analog or digital channels.
- 24 AWG
| Pin | Color | Connection | Analog Mapping | Digital Mapping |
| 1 | Blue | Analog/Digital B1 | Analog 5 | GPIO 1 |
| 2 | Yellow | Analog/Digital B2 | Analog 6 | GPIO 2 |
| 3 | Green | Analog/Digital B4 | Analog 8 | GPIO 4 |
| 4 | Pink | Analog/Digital A1 | Analog 1 | Timer/RPM 1 |
| 5 | White | Analog/Digital A2 | Analog 2 | Timer/RPM 2 |
| 6 | Red | Vref | 5v @ 0.5A | 5v @ 0.5A |
| 7 | Violet | Analog/Digital A3 | Analog 3 | Timer/RPM 3 |
| 8 | Orange | Analog/Digital A4 | Analog 4 | Timer/RPM 4 |
| 9 | Light Green | Analog/Digital B3 | Analog 7 | GPIO 3 |
| 10 | Grey | Ground | ||
| 11 | Brown | Ground | ||
| 12 | Black | Ground |
4 channel extension
M8-4P male to M8-4P female cable extends 4 analog or digital channels. Available in 1 and 2 meter lengths.
4 channel pigtail
M8-8P male pigtail for 4 analog or digital channels. 1 meter length.
- 24 AWG
| 1 | White | Analog/Digital 1 |
| 2 | Yellow | Analog/Digital 2 |
| 3 | Grey | Analog/Digital 4 |
| 4 | Red | 5v reference |
| 5 | Brown | Ground |
| 6 | Pink | 5v reference |
| 7 | Blue | Analog/Digital 3 |
| 8 | Green | Ground |
4 channel splitter
M8-8P Male splits 4 analog or digital channels into 4 M8-3P female connections.
- Connections
- P1 : upstream connection
Single channel extension
M8-3P male to M3-3P female extends a single analog or digital channel. Available in 1, 2, 3, and 4 meter lengths.
Single channel pigtail
M8-3P male pigtail for a single analog or digital connection. 2 meter length.
- 24 AWG
| 3 | Blue | 5v |
| 4 | Black | Signal Input |
Pressure sensor
M8-3P male to 3 pin Delphi GT150 pressure sensor connector. 2 meter length.
| M8 Pin | GT150 Pin | Connection |
| 1 | A | Ground |
| 3 | B | 5v Power |
| 4 | C | Signal |
Linear temperature sensor
M8-3P male to linear temperature sensor. 2 meter length.
- Connector: M8 4P, A coding
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
Dual CAN + power interconnect
- Connector: M8 6P, A coding
| 1 | CAN1 low | |
| 2 | CAN2 low | |
| 3 | CAN2 high | |
| 4 | Ground | |
| 5 | CAN1 high | |
Single analog/digital channel
- Connector: M8 3P, A coding
| 1 | Ground | Brown |
| 3 | Power | Blue (5v @ 1A max) |
| 4 | Signal | Black |
Quad analog/digital channels
| 1 | Analog/Digital 1 | |
| 2 | Analog/Digital 2 | |
| 3 | Analog/Digital 4 | |
| 5 | Ground | |
| 7 | Analog/Digital 3 | |
| 8 | Ground |
Octo analog/digital channels
- Connector: M8 12P, A coding
| 9 | Analog/Digital B3 | Analog 7 | GPIO 3 |
| 10 | Ground | ||
| 11 | Ground | ||
| 12 | Ground |
