Honda B Series Guide
Honda vehicles with B Series engines
Use ECU Pin A13
- RaceCapture/Pro Settings:
- Timer Mode: RPM
- Pulse per revolution: 2
- Timer Speed: Medium
Fuel Level
Fuel Level - Yel/Blk wire. This wire runs from the fuel level sending unit to the gauge cluster.
- If not using the gauge cluster
Disconnect the wire from the gauge cluster. You need to use a 47ohm pull-up resistor. The voltage range is 0.45 (full)- 3.5v (empty).
- Channel settings
- Sample Rate - 1hz
- Smoothing - Max
- Mapped
- 0.45 - 100%
- 3.5 - 0%
Oil Pressure
