PodiumConnect AIM
AIM RaceStudio Setup
Configure your AIM channels/sensors in AIM Race Studio → Channels
Use AIM Online tool to verify channels
Click AIM SmartyCam Functions settings to setup the channels you want exported
Screen Capture or save your Functions to Channels mappings as you will need them later when you look for the CAN Channel ID and Offset for the AIM Function you mapped you sensor channel to.
Here is an example.
Accessing CAN2 for secondary sensor networks
PodiumConnect offers a secondary CAN bus that can be connected to separate sensor networks such as tire temperature, TPMS or other systems. You can also connect this to the secondary CAN bus for your AIM system for additional mapping capabilities.
Molex Connector connection
To add the CAN 2 connection, use the molex pin part number #39-00-0039; you will need two pins for CAN High / CAN Low. After crimping the connector, with your wire, insert the pin into the rear of the molex connector.
You will need to know which sensor you mapped to which AIM Functions in order to add those CAN Channels into PodiumConnect. Each AIM Function has a specific CAN Channel ID and Offset that does not change no matter what sensor is mapped to that Function (See Appendix A Table 2 at bottom of this document). Later we will be referring back to your AIM Functions to Channels mapping that you did here, so keep this window available.
Appendix A: AIM Function to CAN Channel Mappings
(from Step 3)
Use your mappings that you did in from Step 3 above. The pic below is just for reference. Substitute the channels that you used. ie. Whatever sensor you mapped to BRAKE PRESS, it will have a CAN ID of 1058 and OFFSET of 0.
Table 2: AIM Function to CAN Channel and CAN Offset
(AIM Function correlates to table above)
Connect the included cable to your AiM system
You will probably need an AIM 4 port Data Hub in order to use AIM cable, as AIM dash's only have one 5 pin port. Unplug GPS from back of dash, plug the hub into back of Dash, then plug GPS and PodiumConnect cable into hub.
- Note - PodiumConnect can co-exist with an AIM SmartyCam installation - just plug PodiumConnect into the same hub as the Smarty Cam.
Note for Solo DL
In order to power PodiumConnect, you will need to provide 12v power to your Solo DL. PodiumConnect will not run off the Solo DL's internal battery
PodiumConnect Channel Mapping Setup
During the setup Wizard, you would have selected the AIM Smarty Cam channel mappings, which includes the required Speed, Latitude, and Longitude channels, and additional default channels provided by the Smarty Cam mappings.
If these channels do not appear, you can re-import them by selecting Presets and then selecting the PodiumConnect AIM Smarty Cam preset.
Check the RaceCapture Dashboard to see if the AIM data has been imported correctly
Once the presets are enabled and data is flowing via the cable connection, you should see data updating on the RaceCapture dashboard, and the CAN LED on PodiumConnect will be flashing.
Note: The channels shown below are the default examples, you would replace these with the sensors you actually used when mapping the AIM Functions to Channels from from Step 3 above.
The CAN Channel, Offset, and Length is specific to the AIM Funtion. Ie. no matter what sensor you have mapped to EXHAUST TEMP, it will always have a CAN Channel ID of 1057, CAN Offset of 2, and CAN Length of 2.
The suggested Multiplier, Adder, Function, Min/Max, Precision, and Units are specific to the Sensor, not the AIM Function. If you used a different type of sensor for an AIM Function, use the correct Multiplier, Min/Max, etc for that Sensor.
The Hz, Min/Max, Precision, Units, etc are just suggestions for the types of sensors shown. Change to suit your needs. Ie if your car only revs to 6000, change max RPM from 8500 to 6500.
Remove unused channels with invalid data
The default mapping includes most every known AiM channel. If that channel is not being sent from your AiM system, the RaceCapture dashboard will show an invalid 53246 value. Just remove these unused channels in your CAN channel mappings.
Table 3: Default example of CAN Channel Mappings
(AIM Channel name below correlates to Channel in table above)
The Channel mappings (Channel Name, Hz, Channel Min/Max values, Multiplier, and Unit Conversion) will need to be edited and updated for whatever sensors you actually mapped in your AIM SmartyCam settings in Race Studio. You should also delete Channel Mappings you aren't using. IMPORTANT: Definitely either rename AccelX and AccelY if you mapped sensors to them or delete them if unused.
Example: If in Step 3 above, you mapped your DiffTemp sensor/channel to the EXHAUST GAS Function in the AIM SmartyCam settings, you would edit the EGT Channel in RaceCapture and change it to DiffTemp. Because EGT and DiffTemp are both Temp Sensors, the Multiplier and conversions probably would not need to be changed. Min/Max would need to be changed (EGT Max is like 2000 but DiffTemp Max is like 300). If instead you mapped a pressure sensor to EXHAUST GAS Function, you would need to change the Multiplier to 0.01 from the default of 0.1.
CAN Channel Mapping Notes:
1) Channel name is what will show up in your RaceCapture and Podium display. It does not have to exactly match the name you used in AIM.
2) You cannot have 2 Channels in Podium with the same name. Therefore if you already have RPM or EngineTemp or whatever wired into PodiumConnect, you should Customize your AIM CAN Channel name to be slightly different (ie EngineSpd instead of RPM, or Batt instead of Battery).
3) Customizing the Channel Values (click gear icon) allows you to pre-set the Min/Max values for Podium Analysis graphs.
4) Precision is how many decimal points you want recorded and displayed.
8) MASK should be set to 0 for all AIM channels.
9) CAN Bus should be set to 1MB for all AIM channels (unless you wired the AIM CAN wires directly to CAN 2 in back of PodiumConnect).
10) All of the AIM CAN data has a CAN Length of 2.
