RaceCapturePro2 Hardware Install
Power Connection
Connect RaceCapture/Pro to a power source between 9 and 15V. To fully support all devices and outputs, provide at least a 5A fused connection.
Analog Inputs 1-7
  • Input Impedance: 15K ohm
Active Sensors/Signals
Resistive sensor
Analog/Frequency Outputs 1 - 4
ceCapture/Pro provides 3 General Purpose Input Output (GPIO) ports which you can use to control devices (Output mode) or read switches or high / low states of electrical signals.
GPIO channel specifications
Input Mode
Output Mode
Output Behaviour
Frequency/Pulse Input 1 - 3
These input channels can be used to time the duration between digital pulses for purposes of measuring RPM, shaft speed, and so on. The input accepts 0-5V (protected up to 40V). The inputs are high impedance inputs that requires a push-pull source - no internal pullups are provided for maximum signal flexibility. Some sensors, like hall effect sensors may require an external pull-up resistor, wired to 5-12v.
TACH SIGNAL NOTES
CoilX CoilX Sensor Module
LED Indicators
  • Power LED
  • LED1
  • LED2
  • LED3
Pushbutton
Communication Ports
  • Port 1
Used for BT module
  • Port 2
Serial I/O
This section will give you the basic overview of installation best practices.
Location
Picking a location that is easily accessible is key. You will want to mount your RaceCapture so that access to the front of the unit (the side with the lights) is easy. Remember that in a driver's suit your vision and range of motion can be limited, so try to place the unit where the front is visible. For optimal perfomance of your RaceCapture unit, you should place the unit as close to the center of the vehicle's axis's as is possible. This ensures that the lateral accelerations will be minimal in the event of body roll, pitch and rotation.
Orientation
The unit must be mounted squarely with the vehcile. You may rotate it in 90 degree increments in along any of the three axis as you see fit, but the final result must be square against the sides, front and bottom of the vehicle. Rotating anything less than 90 degress along any one axis will lead to inaccurate G-force mesaurements. If you rotate the unit away from its default orientation (described below), you will need to remap the accelerometer when you configure the unit.
Default Orientation
The default configuration is setup so that the front of the unit (the side with the LEDs) is facing towards the rear of the vehicle and the side with the green connector is facing towards the front of the vehicle. The side of the unit with the RaceCapture/Pro sticker is facing up. Below is an image of the default orientation cofiguration:
If your unit installation does not align with this orientation, you will need to re-map the channels in the firmware.
Isolation
Vibration from the vehicle can cause noise in the accelerometers, which can lead to dirty data. Ideally it is best to have some form of isolation between the frame of the vehicle and the RaceCapture unit. Rubber spacers work well as do adhesive strips like the 3M DualLock adhesive strips. These also allow for easy removal of the unit.
