Sequential shift light array
Revision as of 07:08, 26 June 2008 by Brentp (talk | contribs) (added panel drill template)
Kit assembly
Install Resistors
  • R1,R2 Install included 100 ohm resistor (marked 101)
  • R3,R4,R5 Install included 270 ohm resistor (marked 271)
Install LEDs
Install LEDs so that the flat side on the LED case matches the outline on the board silkscreen.
  • Cluster A1,A2: Install green LEDs for L1 - L8
  • Cluster A3,A4: Install yellow LEDs for L9 - L16
  • Cluster A5: Install Red LEDs for L17 - L20
Basic Operation
Wire pad +12v to ignition switched +12V.
To activate the following clusters:
  • Cluster 1: Connect A1 to ground
  • Cluster 2: Connect A2 to ground
  • Cluster 3: Connect A3 to ground
  • Cluster 4: Connect A4 to ground
  • Cluster 5: Connect A5 to ground
Integration with the Megajolt Lite Jr.
User outputs 1-4 + shift light output can be used to control the sequential shift light.
  • Cluster 1: Connect A1 to MJLJ User Output 1
  • Cluster 2: Connect A2 to MJLJ User Output 2
  • Cluster 3: Connect A3 to MJLJ User Output 3
  • Cluster 4: Connect A4 to MJLJ User Output 4
  • Cluster 5: Connect A5 to MJLJ Shift Light Output
Panel Drill Template
Use this image as a drill template if you wish to mount this behind a panel.
200 DPI template
Project Images
Shift light array assembled and illuminated
