MJLJ V4 vehicle installation guide
Parts you will need
- EDIS module: Acquire an EDIS Ignition module matching your engine type- EDIS-4 for 4 cylinder engines; EDIS-8 for 8 cylinders; EDIS-6 for 6 cylinders
Type | Donor Vehicle | Years | Market |
EDIS-4 | Ford Escort | 1990-99 | US |
Ford Fiesta | 1990-93 | Europe | |
Ford Escort | 1990-93 | Europe | |
Ford Sierra | 1990-93 | Europe | |
Ford Mondeo | 1990-93 | Europe | |
EDIS-6 | Ford Ranger Pickup truck | 1990-97 | US |
Mazda B-Series Pickup | 1990-97 | US | |
Ford Explorer | 1990-97 | US | |
Mazda Navajo | 1990-97 | US | |
Ford Aerostar | 1990-97 | US | |
Ford Scorpio 2.9 Cosworth | 1996-97(?) | Europe | |
Ford Mondeo V6 | 1993-1996(?) | Europe | |
EDIS-8 | Crown Victoria | 1990-97 | US |
Mercury Grand Marquis | 1990-97 | US | |
Lincoln Town Car | 1990-97 | US | |
Ford Thunderbird | 1990-97 | US | |
Mercury Cougar | 1990-97 | US | |
Ford Mustang 5.0 | 1990-97 | US |
- Coil packs: Many use the matching Ford coil packs, but typically most OEM coil packs that closely matches the ford EDIS primary(about 0.5 ohms) and secondary(11-13K ohms) DC coil resistance should work fine. Source from donor vehicle, or can be purchased new for a reasonable cost.
- Crank Sensor: We suggest you use a Ford OEM crank sensor- also known as a 'VR (Variable Reluctance) Sensor'- this guarantees best compatibility with the Ford EDIS module. Typically sourced from donor vehicle, or may be purchased new from an auto parts retailer at a low cost (about $20 USD)
- Trigger wheel: The Ford EDIS module requires a 36 tooth wheel with one missing tooth- commonly referred to as a 36-1 wheel. Many adapt the trigger wheel removed from the crank pulley of the donor engine. For example, the Ford Escort 1.9L motor has a crank pulley with a pressed-on ring-shaped trigger wheel when removed, yields a convenient part that can be adapted to the receiving engine. Others machine the pattern directly into the existing crank pulley, fabricate a custom wheel, or purchase a wheel ready made for their engine.
EDIS installation
Type | "N" Degrees BTDC | "N" Teeth |
EDIS-4 | 90 | 9 |
EDIS-6 | 60 | 6 |
EDIS-8 | 50 | 5 |
- Mount the sensor in any convenient way that simplifies bracket design and accomodates mounting points on the engine block.
- Turn the crankshaft to precise Top Dead Center (TDC) for cylinder #1.
- Position the timing wheel onto the crank pulley with the missing tooth aligned with the sensor.
- Now offset the the timing wheel position:
- If your engine turns clockwise when facing the crank pulley, rotate the timing wheel clockwise "N" Teeth.
- If your engine turns counter-clockwise when facing the crank pulley, rotate the timing wheel counter-clockwise "N" Teeth.
- mark this final location of the sensor wheel onto the crank pulley- then weld or bolt timing wheel into place as appropriate.
Megajolt Lite Jr. Wiring
- Use 16 gauge wire for the MJLJ ground connection. 18-20 gauge wiring is fine for signal connections.
- If the MJLJ is fitted with the internal hard rev limiter, it's recommended you use at least 16 gauge wire for +12v power and the Coil Power output, and connect it to a fused circuit with suitable current capacity. Otherwise you may use 18-20 gauge wire for the power connection.
- For MAP based installations ignore the TPS Input.
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Smiths RVI type tachometers
Enabling Option Switch
Rev Limit control
Hard Rev Limit
Soft Rev Limit
Auxiliary Input
Analog input source
Hardware Modification
To enable a 0-5v input, disable R6 by performing this slight modification on the circuit board as shown in the following image.
MJLJ Operation
Verifying MJLJ operation
If the advance does not change, or appears jittery or unstable, see the Troubleshooting Section for additional help.
