PodiumConnect Micro
Quick Start Guide
Connecting the Hardware
Mounting
Pigtail Connection
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Create Your Podium Account
  • Create an account on Podium
  • Setup the Device Name
Windows/OSX
Android/iOS
First-Time Setup Wizard
Configure System Presets
Select Favorite Race Tracks
Verify Telemetry
Comprehensive Setup Guide
Data System Cable Connection
AIM Standard Cable
CAN Bus Configuration
Baud Rate, Termination
CAN Channel Mapping Guide
Telemetry and Logging Setup
Enabling WiFi Telemetry
Setting Sample Rates
SD Card Logging
Buffering Telemetry to SD
Real-Time Podium Features
Firmware and Software Updates
Technical Specifications
