RaceCaptureTrack MK4
Revision as of 09:23, 10 January 2026 by Abdurrehman Akhtar (talk | contribs)
Quick Start Guide
Connecting the Hardware
Mounting
To ensure optimal performance, mount the RaceCapture system on a flat, level surface within the vehicle, with the connectors oriented toward the front. This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
Note: If it is necessary to install the unit in an alternative orientation (e.g., vertical, on-edge, or upside down), ensure it is rotated in clean 90-degree increments relative to the vehicle’s primary axes. Avoid mounting the device at an arbitrary angle, as this can affect sensor accuracy. For non-standard orientations, remap the accelerometer and gyroscope axes in the Setup menu to reflect the installed position.
Connectors
  • RP-SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
Powering up the Module
The RaceCapture/Track MK4 can be powered using the following methods: USB Power (USB Type-C) You may power the device via the USB Type-C port using any of the following sources:
  • A computer USB port
  • A USB car charger
  • A USB battery pack
This method is ideal for quick setup, bench testing, or configuration. Vehicle Power via OBD-II (CAN1 / Power) Alternatively, you can power the module using the vehicle’s OBD-II port by connecting through an OBD-II to M8 4-Pin Female Connector.
Windows / MacOS / Linux
  • Connect your Podium Connect Micro to your computer with the USB cable,
  • Start the RaceCapture app.
Android / iOS
On Raspberry Pi
  • On Android devices, you can also pair via Bluetooth using the default PIN 1234. This can also be changed later in Setup > Wireless.
First Time Wizard Setup
The RaceCapture app will guide you through a brief automated setup and tour. During this process the connection to RaceCapture/Track MK4 will be verified.
Configure System Presets
Select Favorite Race Tracks
LED Status Indicators
LED Function
GPS Indicates GPS status:
Comprehensive Setup Guide
Data System Cable Connection
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
1 CAN 1 Low
2 CAN 2 Low
3 CAN 2 High
4 Ground
5 CAN 1 High
6 Power 9–24V / 1A (~12W)
The RaceCapture/Track MK4 supports plug-and-play OBD-II connectivity along with dual CAN bus network support, enabling seamless integration with both OEM and aftermarket ECUs.
CAN Channel Mappings
