AnalogX2
In the kit you will receive:
  • AnalogX2 module
Harness / Cabling
AnalogX2 connects directly to the RaceCapture CAN bus using the Autosport Labs plug-and-play harness system. Two common connection configurations are shown below.
Simple Connection (Single Device) In the simplest configuration, AnalogX2 is connected to the CAN2 branch of the RaceCapture CAN1/CAN2 splitter. An inline CAN terminator is placed at the end of the bus. This configuration is recommended when AnalogX2 is the only CAN device on that branch.
Inserted Into CAN Bus With Additional Devices
AnalogX2 can also be inserted into an existing CAN bus using a single CAN splitter. In this configuration, the CAN bus continues to other devices such as ShiftX3 or TireX, and the inline CAN terminator is placed at the end of the bus.
SKU Description
ASL_M8_CAN_EXT_0.5M
ASL_M8_CAN_EXT_1M
ASL_M8_CAN_EXT_2M
ASL_M8_CAN_EXT_3M
ASL_M8_CAN_EXT_4M
CAN extension cable, M8 4P female to M8 4P male, 0.5 - 4 Meter lengths
Sensor Connections
SKU Description
ASL_M8_SENSOR_EXTENSION_1M
ASL_M8_SENSOR_EXTENSION_2M
ASL_M8_SENSOR_EXTENSION_3M
ASL_M8_SENSOR_EXTENSION_4M
Bare pigtails
SKU Description
Compatible Sensors
  • Note - RaceCapture's CAN mapping features currently only supports sensors with a linear (straight-line) response. Sensors with a curved response, such as the Extended Range Temperature sensor is based on a thermistor design, and will not work with the built-in direct CAN mapping. We recommend using a temperature sensor with a linear response, such as the Autosport Labs Linear Temperature Sensor, Texense Liquid Temperature Sensor or similar.
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
  • 0.5v 0 bar / = 0 PSI
  • 4.5v = 10 bar / 150 PSI
Therefore,
  • Note:: The 0.0375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
  • 0.5v = 0 bar / 0 PSI
  • 4.5v = 150 bar / 2175 PSI
Other sensors
Power and CAN
Pin Connection Notes
1 CAN low
2 Power Red, 12-14v / 50mA
3 CAN high
4 Ground Black
Sensor connections
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
  • Note: The AnalogX inputs are very high impedance, allowing connection to existing circuits / sensors without affecting the reading of that circuit. As such, no pull-up or pull-down resistors are provided and must be added externally if needed.
DIP switch settings
Switch Function Description
CAN termination
No CAN data
  • Ensure AnalogX is receiving 12v via it's connection.
    • Note: Ensure your data system is also receiving 12v if it is powering AnalogX
Basic mapping test
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Weight 100gm (approximately)
Environmental IP65, 0-85C
AnalogX CAN bus API
Adjusting Base ID
Off Off 0xE4600 (935424)
Off On 0xE4700 (935680)
On Off 0xE4800 (935936)
On On 0xE4900 (936192)
Address
CAN ID: Base + 0x0 (0)
Offset What Value
1 Current sample rate, in Hz
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
  • Note: To read the current settings, broadcast a message with this CAN ID with no data (data length of 0) - AnalogX will reply with the current configuration.
Address
CAN ID: Base + 0x3 (3)
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
CAN ID: Base + 0x2 (2)
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 0x14 (20)
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
