IgnitionDrivers
Revision as of 22:04, 11 October 2011 by Brentp (talk | contribs) (changed IGBT to on Semi)
Ignition Driver boards
Jolt4 Ignition Driver
The Jolt4 Ignition Driver board groups together 4 Ignition drive transistors such as the Bosch BIP373 , On Semi NGB8202NT4G and so on.
  • Up to 4 ignition drivers supported
  • 10 pin molex connector for ease of use
  • LEDs indicating driver activity (requires additional drive current of 3-6ma)
  • Heat-sinking from bottom of PC board- transistors are soldered down
  • 2.48 x 3.14" board sized to fit our compact aluminum enclosure (or other enclosure accepting 2.5" width PC Boards)
  • Metric sizing for board is 63mm x 80mm
Connector Pinout
License
This design is released under the Autosport Labs Creative Commons license
Downloads
Revision A Hardware
