RaceCapturePro Sensors
Revision as of 17:11, 5 January 2013 by Brentp (talk | contribs)
Sensor Breakout Board
Engine Temperature
GM
  • Pigtail Pico 5615pt
GM
  • Pigtail Pico 5616pt
Oil Temperature
Ambient Air Temperature
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position
Linear Sensors
