RaceCapturePro Sensors
Engine Temperature
Oil Temperature
Ambient Air Temperature
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Sensor Breakout Board
