RaceCapturePro Sensors
Engine Temperature
GM
  • Pigtail Pico 5615pt
GM
  • Pigtail Pico 5616pt
Oil Temperature
Ambient Air Temperature
Infrared Tire Temperature
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
TI Needs dev board to connect to inputs. Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT *Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor <link to Race Capture digital channel configuration> Can be used for 3 position tire temperature, when mounted within 3" of tire
GM 3.3 bar MAP sensor
  • Sensor: 9373269
  • Pigtail: 88987997
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Sensor Breakout Board
SensorX
