RaceCapturePro Sensors
Revision as of 21:41, 16 July 2013 by Brentp (talk | contribs) (→Wiring: added temp sensor wiring)
Engine Temperature
GM
  • Pigtail Pico 5615pt
GM
  • Pigtail Pico 5616pt
Oil Temperature
Ambient Air Temperature
Infrared Tire Temperature
TI Infrared Temperature Sensor samples 3 positions on tire carcass Needs dev board to connect to inputs. Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT *Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor <link to Race Capture digital channel configuration> Can be used for 3 position tire temperature, when mounted within 3" of tire link
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Tire Pressure
Boost / Vacuum
GM 3.3 bar MAP sensor
  • Sensor: 9373269
  • Pigtail: 88987997
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Temperature Sensor
Pullup resistor
A pullup resistor is needed to create the necessary voltage divider circuit so RaceCapture/Pro's analog input can sense temperature as a varying voltage.
  • VDO 323-095, 325-002
Sensor Ground
Sensor Breakout Board
SensorX
