RaceCapturePro TelemetryQuickstart
Unbox
Purchasing SIM Card
  • T-Mobile
  • AT&T
Installing SIM card
  • open telemetry enclosure
  • unlatch simcard holder
  • insert SIM card
  • latch simcard holder in place
  • re-assemble case
Connect components
Telemetry Module
  • Plug cable in to connectivity expansion port
Connect GPS to RaceCapture
  • Connect GPS module to GPS port
Connecting Antenna
  • Connect antenna to RF port
    • Don't overtorque!
Creating RCLive account & get device Id
Install RaceAnalyzer
Configure RaceCapture/Pro
Set channel sample rates
The default sample rates are too high for real-time telemetry, set the following sensors to these recommended values:
  • GPS 1Hz -5Hz
  • Accelerometer 5Hz
Set device id
Write configuration
  • Power cycle RCP
Testing
Connect to real power source (NOT USB) or connect to powered USB Hub with extra juice eg: http://www.amazon.com/Sabrent-Powered-adapter-compatible-HB-USB30/dp/B00BJPRI1Y/ref=sr_1_3?ie=UTF8&qid=1367991516&sr=8-3&keywords=usb+hub+high+power http://www.amazon.com/D-Link-DUB-H7-High-Speed-7-Port/dp/B00008VFAF/ref=sr_1_5?ie=UTF8&qid=1367991578&sr=8-5&keywords=usb+hub+high+power Watch LEDs on telemetry device explain / document LED flashing Press log button Got to race-capture.com/home, look for a new event, click on it
TaDa!
