RaceCapturePro TelemetryQuickstart
Unbox
Purchasing SIM Card
  • T-Mobile
  • AT&T
Installing SIM card
  • open telemetry enclosure
  • unlatch simcard holder
  • insert SIM card
  • latch simcard holder in place
  • re-assemble case
Connect components
Telemetry Module
  • Plug cable in to connectivity expansion port (the port closest to the LEDs)
Connect GPS to RaceCapture
  • Connect GPS module to GPS port (port next to the telemetry port)
Connecting Antenna
  • Connect antenna to RF port
    • Don't overtorque!
  • Go to http://www.race-capture.com, click on Signup in the top navigation
  • Create your account
Install RaceAnalyzer
Configure RaceCapture/Pro
Set channel sample rates
The default sample rates are too high for real-time telemetry, set the following sensors to these recommended values:
  • GPS 1Hz -5Hz
  • Accelerometer 5Hz
Set device id
Write configuration
Testing
Watch LEDs on telemetry device explain / document LED flashing Got to race-capture.com/home, look for a new event, click on it
TaDa!
