RaceCapturePro TelemetryQuickstart
Revision as of 14:06, 9 May 2013 by Brentp (talk | contribs) (added image links)
Unbox
Purchasing SIM Card
  • T-Mobile
Purchase a pre-paid SIM card from your local t-mobile dealer. We recommend picking a plan with the 2G/3G unlimited data, which is currently $3 USD / day of actual usage.
  • AT&T
AT&T is not currently supported; expect support soon in an upcoming firmware version.
Installing SIM card
  • open telemetry enclosure
Unscrew the end plate on the antenna side of the telemetry module: Telemetry unit half in enclosure.jpg
  • unlatch simcard holder
  • insert SIM card
  • latch simcard holder in place
  • re-assemble case
Slide board back into enclosure. ensure LEDs are aligned with end plate and reattach end plate with screws.
Connect components
Telemetry Module
  • Plug cable in to connectivity expansion port (the port closest to the LEDs)
Connect GPS to RaceCapture
  • Connect GPS module to GPS port (port next to the telemetry port)
Connecting Antenna
  • Connect antenna to RF port
    • Don't overtorque!
  • Go to http://www.race-capture.com, click on Signup in the top navigation
  • Create your account
Install RaceAnalyzer
Configure RaceCapture/Pro
Set channel sample rates
The default sample rates are too high for real-time telemetry, set the following sensors to these recommended values:
  • GPS 1Hz -5Hz
  • Accelerometer 5Hz
Set device id
Add your device id that you wrote down when adding your device to race-capture.com to the Telemetry Device Id field under the Logging/Telemetry section: Devicesetup.png
Write configuration
Testing
Watch LEDs on telemetry device explain / document LED flashing Got to race-capture.com/home, look for a new event, click on it
TaDa!
