RaceCapturePro installation guide
Revision as of 20:58, 19 October 2013 by Brentp (talk | contribs) (added rubber mounts link)
Shock isolation mounting
In very harsh environments you may want to mount RaceCapture/Pro using rubber isolators. Source of vibration isolating mounts
Terminal block connections
Connections facing terminal block, from left to right. 20 gauge wire works well for the connections.
  1. Ground
  2. +12v
  3. Analog/Frequency out 4
  4. Analog/Frequency out 3
  5. Analog/Frequency out 2
  6. Analog/Frequency out 1
  7. +5V Voltage reference
  8. Analog input 7
  9. Analog input 6
  10. Analog input 5
  11. Analog input 4
  12. Analog input 3
  13. Analog input 2
  14. Analog input 1
  15. General purpose input/output 3
  16. General purpose input/output 2
  17. General purpose input/output 1
  18. Frequency/pulse input 3
  19. Frequency/pulse input 2
  20. Frequency/pulse input 1
Power Connection
Analog Inputs 1-7
  • Active Sensors/Signals
  • Resistive sensor
Analog/Frequency Outputs 1-4
Frequency/Pulse Input 1-3
TACH SIGNAL NOTES
Interfacing directly to the signal of the coil pack primary will require an opto-isolated interface board such as the design here, currently under testing. Other interface boards can be used, provided they provide a clean square wave signal to RaceCapture/Pro.
Expansion Port
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • LED1
  • LED2
  • LED3
Pushbutton
Communication Ports
  • Port 1
  • Port 2
Used for GPS module
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
JTAG header
