RaceCapturePro installation guide
Shock isolation mounting
Terminal block connections
Connections facing terminal block, from left to right. 20 gauge wire works well for the connections.
- Ground
- +12v
- Analog/Frequency out 4
- Analog/Frequency out 3
- Analog/Frequency out 2
- Analog/Frequency out 1
- +5V Voltage reference
- Analog input 7
- Analog input 6
- Analog input 5
- Analog input 4
- Analog input 3
- Analog input 2
- Analog input 1
- Frequency/pulse input 3
- Frequency/pulse input 2
- Frequency/pulse input 1
Power Connection
Analog Inputs 1-7
- Active Sensors/Signals
- Resistive sensor
Analog/Frequency Outputs 1-4
Frequency/Pulse Input 1-3
TACH SIGNAL NOTES
Interfacing directly to the signal of the coil pack primary will require an opto-isolated interface board such as the design here, currently under testing. Other interface boards can be used, provided they provide a clean square wave signal to RaceCapture/Pro.
Expansion Port
SD Card Slot
USB Port
LED Indicators
- Power LED
- LED1
- LED2
- LED3
Pushbutton
Communication Ports
- Port 1
- Port 2
Used for GPS module
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
JTAG header
