RaceCapturePro Sensors
GM Style fluid sensors
Analog channel configuration
- Using 2.2K pullup resistor
| Volts | Scaled Value (Degrees F) |
| 0.37 | 212.00 |
| 0.51 | 178.00 |
| 1.99 | 104.0 |
| 2.47 | 72.0 |
| 4.24 | 23.0 |
AEM Sensors
| Part # | Pic | Mechanical | Notes |
| AEM-30-2012 | 1/8" NPT |
| 0.40 | 302.00 |
| 0.87 | 239.00 |
| 1.88 | 176.0 |
| 3.2 | 122.0 |
| 4.72 | 32.0 |
Infrared Tire Temperature
| Mfg | Description | Pic | Pigtail | Part Numbers | Mechanical | Analog Configuration | Notes |
| TI | Infrared Temperature Sensor samples 3 positions on tire carcass | Needs dev board to connect to inputs. | Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT | *Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor | <link to Race Capture digital channel configuration> | Can be used for 3 position tire temperature, when mounted within 3" of tire link |
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Tire Pressure
| VDO | REDI-Sensor™ Multi-Application TPMS Sensors | self powered wireless | OEM style | custom | Wireless tire pressure monitoring system link | ||
| ASL | Ford type throttle position sensor | turnkey unit | custom self powered wireless | Wireless tire pressure monitoring system includes wireless receiver and gauge link |
Boost / Vacuum
Distance Sensors
Suspension Travel
| Vishay Semiconductors | Specialized Optical Switch | 3-pin connector | Mouser Part #:782-TCND5000 Manufacturer Part #:TCND5000 | Optical Switches, Specialized Reflective Sensor w/PIN Photodiode Out | <link> | Optical distance sensor to be used for pedal travel as well, providing there is a target to sense Link |
Angle Sensors
Steering Angle
Throttle Position
| ASL | Ford type throttle position sensor | see pigtail below | Standard Motors SMP TH45 equivalent | custom | Existing style Throttle position sensor available from AutoSport Labs link | ||
| ASL | Ford type throttle position sensor | 3-pin connector | fits SMP TH45 above | custom | Existing style Throttle position sensor available from AutoSport Labs link |
Brake Position/Pressure
| ATE | Brake Fluid Pressure sensor | solder on tabs (2 wire) | If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237. | <link to Race Capture analog channel configuration> | threads into T fitting on brake line. Use professional brake fitting tools! link | ||
| DIY | Freescale MPX4250AP 2.5 bar MAP sensor | on part | ATV type sensor | threads into T fitting on brake line. Use professional brake fitting tools! | avail at 150psi, or 2000psi, needs 12v supply link |
Linear Sensors
Temperature Sensor
Pullup resistor
- GM-style TX3 / SU109 Coolant
- GM-style AX1 / SU107 Air Inlet Temp
- AEM 30-2012 1/8" NPT fluid temperature sensor
- VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
