RaceCapturePro Sensors
GM-Style | |||||||||||||||||
Pico 5615pt |
Pico 5616pt |
AEM | |||||||||||||||||
| AEM-30-2012 |
| Mylexis MLX90620 |
3 bar MAP sensor |
| Freescale MXP4250AP |
2.5 bar MAP sensor
| Schrader |
RPM | |||||||||||||||||
| Autosport Labs CoilX | <image> | The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | |||||||||||||||
| Cherry GS102301 | File:Cherry GS102301 gear speed sensor.jpg |
| Cherry GS100701 |
| Sharp GP2D12 |
| Ford / SMP TH45 |
Common Ford style Throttle Position sensor | ||||||||||||||||
Temperature Sensor
Pullup resistor
- GM-style TX3 / SU109 Coolant
- GM-style AX1 / SU107 Air Inlet Temp
- AEM 30-2012 1/8" NPT fluid temperature sensor
- VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
