RaceCapture App User's Guide
BETA STATUS
This software is currently in beta for those who wish to test new features.
- OS X: experimental support - USB interface fails to communicate (possible driver issue)
- Android: port scheduled
- iOS: port scheduled
Discussion Forums
Please post all of your testing feedback and questions in the Forums
Warnings
Please heed these warnings:
- Expect it to fail suddenly
- Expect it to not record or transmit data correctly
- Expect it to save or read configuration data incorrectly
- Expect to have to re-create your configuration data after updating firmware
- Expect it to not serve up hot brewed espresso drinks
However, with your testing and feedback, we'll quickly transition to full production status for all of the big features we've been working on.
What's New
Check out some kickass new features:
Capable of running on Windows, OS X, Linux, iOS and Android, the new RaceCapture app will ultimately combine RaceAnalyzer and the current Mobile app into a unified configuration, dashboard and analysis solution.
With this beta/preview release the RaceCapture app will initially support configuration for RaceCapture/Pro system running the V2 firmware. Dashboard and then Analysis features will follow to make the official application launch.
The latest race track configurations can be automatically downloaded and synchronized from http://www.race-capture.com via the application. If your track is not in the list, email us at [email protected] and we will work to get it added.
Multi-Sector Timing
Separate Start/Finish Lines
Not yet implemented To enable auto-x/rally/hillclimb scenarios we've enabled the ability to define a separate start and finish line.
Predictive Lap Timing
Streamlined Sensor and Channel Configuration
Channel configuration has been simplified where possible with additional default settings that make sense. Automatic channel configuration wizards will help auto-calibrate things like throttle position, fuel level and and steering angle sensors.
CAN bus expansion
OBD2 support
(insert OBD2 configuration here)
Virtual Channels
(link to Lua scripting reference, add code example)
Channel Filtering
Analog, Timer and Accelerometer channels feature an adjustable dampening filter that allows you to smooth out sensor readings as needed. Examples of this use:
- Filtering accelerometer readings for rough environments
- Averaging fuel level readings to compensate for fuel tank slosh
Channel Customization
The concept of a channel has been formalized into a set of universal system level channels where min/max and unit labels can be customized. Additionally, user-defined channels can be defined for special purpose channels.
Improved Lua Scripting
- Using the print() and println() you can print out log messages which will show up in the scripting view. Great for debugging.
- If a wayward script somehow crashes the firmware, the RCP watchdog will fire and start up RCP in safe mode, illuminating the red LED and bypassing script execution. Then, you'll have a chance to make fixes.
- Functions have been streamlined and normalized. Additional Lua functions have been added to support virtual channels, OBDII and CAN bus messaging.
Improved log timing accuracy
Upcoming Features
Dashboard
- Multi-gauge dashboard view
Analysis
- Line charts showing channels over distance, with the ability to combine multiple channels into a single chart
- GPS plots showing the line taken in reference to the center line of the track map
- Sector times for each part of the track
Firmware
- Windows: Check under Device Manager for a RaceCapture/Pro device under the Ports section.
- Linux: When plugged in, a CDC-ACM device should show up. Check it by issuing the dmesg command; typically it will be /dev/ttyACM0
Application
Install the beta RaceCapture app after downloading the setup package from the downloads section.
Running
Editing Configuration
Auto track detection
GPS Configuration
Analog Channels
- Raw value
- Simple linear scaling
- Interpolated map
- Note Channel #8 is fixed as a battery input channel and should not be changed.
Pulse/RPM Sensors
- Channel Operation Mode: RPM, frequency, or pulse period
- Clock divider: This specifies the operating range for measuring the pulse. This is typically left at 128.
- Pulse Per Revolution / Teeth Per Wheel: This specifies the number of pulses representing a complete revolution of the wheel.
- For RPM mode This value is typically set based on the number of cylinders and the number of coil packs used on the engine
Digital In/Out
- Mode: Set the channel to input for reading digital on/off sensors, or output to use the channel in output mode to control a device.
Accelerometer/Gyro
- Not yet implemented User interface for zeroing accelerometer/gyro channels.
Pulse/Analog Out
- Output Mode Select either Frequency / Pulse Width Modulated (PWM) mode or analog output mode. Note, to enable analog mode you also need to flip the hardware dip switch on the RaceCapture/Pro main board.
- Logging Mode Select either logging the frequency or the analog output voltage.
- Startup Duty Cycle this is the default duty cycle when the system starts up.
- Startup Period this is the period of the pulse - a larger number means individual pulses are spread further apart.
CAN Bus
OBD II
