Revision as of 19:48, 17 March 2007 by Brentp (talk | contribs) (Adding stubs for MJLJ operation)
EDIS installation
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
Installing the MJLJ
MJLJ wiring notes and guidlines
  • Use shielded cable for the PIP/SAW signal between the MJLJ and EDSI module. Be sure to ground the shield as well. A 2-conductor cable with a foil sheild works well.
Interfacing to Tachometers
Tachometers that require a HV kickback pulse
Some OEM-style tachometers detect the RPM signal by sensing the high voltage flyback pulse from the ignition coil. In distributor based setups, there is only one ignition coil to detect this pulse from. With a wasted spark system, this 'signal' is spread across multiple coils. As a result, you will need a way to combine these pulses across multiple coil packs to drive your tachometer.
OEM tach adapter circuit
User defined outputs
Rev Limit control
