EDIS installation
Wiring notes and guidelines
Installing the MJLJ
MJLJ wiring notes and guidlines
- Use shielded cable for the PIP/SAW signal between the MJLJ and EDSI module. Be sure to ground the shield as well. A 2-conductor cable with a foil sheild works well.
Interfacing to Tachometers
Tachometers that require a HV kickback pulse
Some OEM-style tachometers detect the RPM signal by sensing the high voltage flyback pulse from the ignition coil. In distributor based setups, there is only one ignition coil to detect this pulse from. With a wasted spark system, this 'signal' is spread across multiple coils. As a result, you will need a way to combine these pulses across multiple coil packs to drive your tachometer.
OEM tach adapter circuit
User defined outputs
The User defined outputs provided by the MJLJ can be set to trigger on either RPM or Load thresholds. The configuration of these outputs is provided by the PC configuration software, covered in a later section.
Should you exceed the current capacity of one or more of the user defined outputs and damage the ULN2003 chip, replace the chip with a new unit- it is socketed for this specific reason.
