Parts you will need
EDIS installation
| Type | Degrees BTDC |
| EDIS-4 | 90 |
| EDIS-6 | 60 |
| EDIS-8 | 50 |
With the Engine at TDC for cylinder #1, the sensor should be positioned 'N' degrees before the missing tooth. Make sure you take into account the rotation of the engine: clockwise or counter-clockwise, when determining your sensor mounting.
Wiring notes and guidelines
Installing the MJLJ
Interfacing to Tachometers
The four User defined outputs provided by the MJLJ can be set to trigger on either RPM or Load thresholds. The separate 'shift light' output triggers only on RPM, but otherwise behaves identically to the user outputs.
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
After you've double-checked the wiring of the MJLJ, connect a timing light and start the engine. You should observe the ignition advance changing in precise steps in response to throttle changes. If the advance does not change, or appears jittery or unstable, verify your MJLJ installation, especially the PIP / SAW connection, proper grounding and cable shielding.
