Parts you will need
- EDIS-8 for 8 cylinder
- EDIS-6 for 6 cylinder
- EDIS-4 for 4 cylinder
EDIS installation
| Type | Degrees BTDC |
| EDIS-4 | 90 |
| EDIS-6 | 60 |
| EDIS-8 | 50 |
Wiring notes and guidelines
Installing the MJLJ
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
