Parts you will need
    • EDIS-8 for 8 cylinder
    • EDIS-6 for 6 cylinder
    • EDIS-4 for 4 cylinder
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
Installing the MJLJ
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
====Using EDIS PIP signal==== An alternate approach that appears to work with older 'Smiths' type tachometers is to share the PIP signal that is emitted from the EDIS module. The PIP output is a 12V square wave with a larger duty cycle than the TACH_OUT provided by the MJLJ. Simply wire the EDIS PIP output to both the MJLJ PIP input as well as the tachometer sense wire. If this approach is used, you should check to make sure the MJLJ receives the PIP signal consistently, since the PIP line has extra current demand placed upon it. The current demands of the MJLJ PIP input is low, so it should work fine- and a few field reports have shown this. However, a quick check using the configuration software for consistent RPM readings would be prudent.
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
