How To Update Firmware
RaceCapture/Pro MK2
Save your configuration
- Press the 'Configuration' button to navigate to the configuration section.
- On the left menu, select Firmware
- On the firmware screen, press the button "Update Firmware"
- Navigate to the firmware file ending in ".ihex"
- Select this file. The firmware will update and show a percentage progress indicator.
- If there is a problem detecting RaceCapture/Pro, unplug/replug and restart the app.
Alternative method
- While holding down the button on RaceCapture/Pro, power it up by plugging in to USB.
- You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
- Navigate to the configuration/firmware update screen, select the firmware file and update the firmware.
RaceCapture/Pro MK1
Note: if you have problems getting RaceCapture/Pro recognized in bootloader mode, try installing the bootloader drivers while the hardware is plugged in to USB in bootloader mode (hold down logging button on RaceCapture/Pro, plug in to USB, then release button)
