Revision as of 18:00, 21 October 2007 by Brentp (talk | contribs) (→EDIS Wiring notes and guidelines: grammatical change.)
Parts you will need
    • EDIS-8 for 8 cylinder
    • EDIS-6 for 6 cylinder
    • EDIS-4 for 4 cylinder
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
    • RF Suppression Capacitor - The capacitor often found attached to the OEM coil packs is designed to minimize electrical & RF interference. If it's convenient to leave connected, you may do so; however many installations have omitted this capacitor without issue. If you experience static in your radio or have sensitive electrical equipment, you may include it to see if it solves your problem.
Installing the MJLJ
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Using EDIS PIP signal
An alternate approach that appears to work with older 'Smiths' type tachometers is to share the PIP signal that is emitted from the EDIS module. The PIP output is a 12V square wave with a larger duty cycle than the TACH_OUT provided by the MJLJ. Simply wire the EDIS PIP output to both the MJLJ PIP input as well as the tachometer sense wire.
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
