AIM CAN
This section documents how to control an AIM Mychron3 Dash display, using an RCP unit via LUA scripting. The following information is a sum up of reverse engineering findings documented here: [1]. Examples of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below.
rpm = getChannel(rpmId)
speedmph = getChannel(speedMphId)
gear = getChannel(gearId)
msg = {rpm % 256, rpm / 256, (speedmph % 16) % 256, (speedmph / 16) / 256, 0, 0, gear, 0}
txCAN(0, 1025, 0, msg)
TODO
Packet 404h: Control for fields displayed on bottom left of display
TODO
TODO
TODO
Packet 408h: Timing
TODO
