AIM CAN
Revision as of 03:34, 9 January 2015 by Jstoezel (talk | contribs) (→Packet 402h: Temperature/Pressure fields (bottom left of display))
This section documents how to control an AIM Mychron3 Dash display, using an RCP unit via LUA scripting. The following information is a sum up of reverse engineering findings documented here: [1]. Examples of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below.
function onTick() local rpm = getTimerRpm(0) local speedmph = getGpsSpeed() -- Assume the gear is calculated and stored in a virtual channel. -- Refer to LUA scripting example to calculate the gear based on speed and RPM local gear = getChannel(gearId) local msg = {rpm % 256, rpm / 256, (speedmph % 16) % 256, (speedmph / 16) / 256, 0, 0, gear, 0} txCAN(0, 1025, 0, msg) end
function onTick() -- Assume different temperature values are stored in virtual channels local temp1 = getChannel(temp1Id) local temp2 = getChannel(temp2Id) local temp3 = getChannel(temp3Id) local temp4 = getChannel(temp4Id) local msg = {temp1 % 256, temp1 / 256, temp2 % 256, temp2 / 256, temp3 % 256, temp3 / 256, temp4 % 4, temp4 / 256} txCAN(0, 1026, 0, msg) end
TODO
TODO
Packet 408h: Timing
TODO
