Emtron
Emtron ECU
Configuration
This script integrates the Emtron ECU with RaceCapture/Pro telemetry.
Baud Rate
Baud Rate is:
Channels
TPS
- CAN ID: 1251
- Bytes: 5,6
- Scaling: 0 = -100.0% ; 2000 = 100.0%
Lua Script
setTickRate(30) --30Hz
--set up virtual channels
tps_id = addChannel("TPS", 10, 1)
--handle TPS message data
function process_tps(data)
local tps = data[5] * 256 + data[6]
tps = (tps - 1000) / 10
setChannel(tps_id, tps)
id, e, data = rxCAN(0)
if id == 1251 then process_tps(data) end
until id == nil
