Emtron
Emtron ECU
Configuration
This script integrates the Emtron ECU with RaceCapture/Pro telemetry, using the factory standard CAN bus mapping
Baud Rate
The default baud rate for Emtron is 1mbps.
- You can configure this on the CAN bus configuration page in the RaceCapture App.
Channels
TPS
- CAN ID: 1251
- Bytes: 1,2 (little endian)
- Scaling: 1000 = 0.0% ; 2000 = 100.0%
- Precision: 0.1
Lua Script
setTickRate(30) --30Hz
--set up virtual channels
tps_id = addChannel("TPS", 10, 1)
--handle TPS message data
function process_tps(data)
local tps = (data[2] * 256 + data[1]) * 0.1
setChannel(tps_id, tps)
id, e, data = rxCAN(0)
if id == 1251 then process_tps(data) end
until id == nil
