Emtron
Emtron ECU
Configuration
This script integrates the Emtron ECU with RaceCapture/Pro telemetry, using the factory standard CAN bus mapping
Baud Rate
The default baud rate for Emtron is 1mbps.
- You can configure this on the CAN bus configuration page in the RaceCapture App.
Channels
TPS
- CAN ID: 1251
- Bytes: 1,2 (little endian)
- Scaling: 1000 = 0.0% ; 2000 = 100.0%
- Precision: 0.1
Lua Script
setTickRate(30) --30Hz --set up virtual channels tps_id = addChannel("TPS", 10, 1) --handle TPS message data function process_tps(data) local tps = ((data[2] * 256 + data[1]) - 1000) * 0.1 setChannel(tps_id, tps) end function onTick() repeat --will drain CAN buffer on each tick id, e, data = rxCAN(0) if id == 1251 then process_tps(data) end until id == nil end
