How To Update Firmware
Revision as of 22:29, 22 June 2015 by Brentp (talk | contribs)
RaceCapture/Pro MK2
Save your configuration
Alternative method
  • You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
RaceCapture/Pro MK1
Alternatively:
Mac Users
For Mac users you will need to use a Windows VM to connect to RCP. Free virtual machine images are available here: http://dev.modern.ie/tools/vms/ You will need to add a network adapter to the VM. After that follow the Windows instructions.
