AIM SmartyCam CAN
Under Development
Pictures
CAN database
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
fuelId = addChannel("Fuel", 1, 0, 0, 60, "L")
oilPresId = addChannel("OilPressure", 10, 0, 0, 10, 'Bar')
CAN_map = {
[1056] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(tempId, data, 6, 2, 0.1, 0) end,
[1057] = function(data) map_chan(oilTempId, data, 4, 2, 0.1, 0) map_chan(OilPresId, data, 6, 2, 0.01, 0) end,
[1058] = function(data) map_chan(tpsId, data, 2, 1, 1, 0) end ,
[1070] = function(data) map_chan(fuelId, data, 0, 1, 1, 0) end
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
initCAN(CAN_chan, CAN_baud)
