CAN Bus logger
The following script will output all CAN bus messages received on CAN channel 1 to the RaceCapture/Pro log window.
After writing the script, you can observe the output in the log monitor window in the RaceCapture app.
  • Click the checkbox next to Poll Logfile to see the CAN bus datastream
Using a Terminal Program
However, to gather large amounts of data, we recommend connecting directly to RaceCapture/Pro's serial console using a terminal program like Hyperterminal, RealTerm, minicom or similar.
  • Close the RaceCapture app
  • Connect to the RaceCapture device using HyperTerminal, RealTerm or Minicom using the COM port assigned by the operating system.
  • Press <Enter> to see a list of commands
  • View the log by issuing the command 'viewLog' at the serial console.
  • You will see a dump of the CAN bus data to the screen.
--500K baud. set your baud rate here.
initCAN(0, 500000)
setTickRate(30)  --onTick() will be called at 30Hz.
--this function drains all pending CAN messages
--and outputs messages to the log
function outputCAN()
	repeat
		id, ext, data = rxCAN(0, 100)
			print(id ..', ')
			for i = 1,#data do
				print(data[i] ..', ')
			println('')
	until id == nil
	outputCAN()
