AIM SmartyCam CAN
This CAN bus integration maps CAN bus data from AIM systems normally directed to AIM's SmartyCam camera system.
Since the SmartyCam protocol is standard across AIM products, connecting RaceCapture/Pro to the CAN interface of an AIM product compatible with SmartyCam, communications can be intercepted and data can be mapped to RaceCapture/Pro telemetry channels.
Pictures
CAN database
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
fuelId = addChannel("Fuel", 1, 0, 0, 60, "L")
oilPresId = addChannel("OilPressure", 10, 0, 0, 10, 'Bar')
CAN_map = {
[1056] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(tempId, data, 6, 2, 0.1, 0) end,
[1057] = function(data) map_chan(oilTempId, data, 4, 2, 0.1, 0) map_chan(OilPresId, data, 6, 2, 0.01, 0) end,
[1058] = function(data) map_chan(tpsId, data, 2, 1, 1, 0) end ,
[1070] = function(data) map_chan(fuelId, data, 0, 1, 1, 0) end
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
initCAN(CAN_chan, CAN_baud)
