MJLJ V3 Operation Guide
First time use
Setting the Serial Port
Configuring MAP or TPS
Otherwise, select 'Forced Induction' if your engine is turbocharged or supercharged. This will set the maximum scale to 255KPa (about 21 PSI of boost)
Connecting to the MJLJ
After the COM port is configured, connect the serial cable to the MJLJ and apply power. If you already have the MJLJ wired into your engine's wiring harness, turn the ignition key to 'on'. If you are testing the MJLJ on the bench, you can simply power the unit with a 9V battery or a suitable 9-15V power supply.
The first way to verify connectivity is to observe runtime data on the screen. On a running engine you'll see the real-time RPM, Load and ignition advance values on the gauges at the bottom of the window.
If you're testing on the bench or on a non-running engine, you will still be able to observe runtime activity by simulating load changing on the engine. For TPS- move the accelerator pedal; MAP- you can manually apply pressure or vacuum.
Updating the Ignition Configuration
Making the changes permanent
Configuration Options
Configuring TPS
Choosing between Normally Aspirated and Forced Induction
Switchable Ignition maps
Ignition Map View
Runtime View
Tuning View
Data logging
Advanced Topics
