AEM Inifinity 6H ECU
setTickRate(25)
initCAN(0, 500000)
CAN_chan = 0
CAN_map = {
[32546816] = function(data)
map_chan(rpmId, data, 0, 2, 0.39063, 0)
map_chan(tpsId, data, 4, 2, 0.0015259, 0)
map_chan(atsId, data, 6, 1, 1, 0)
map_chan(ctsId, data, 7, 1, 1, 0)
end,
[32546820] = function(data)
map_chan(fpsId, data, 3, 1, 0.580151, 0)
map_chan(opsId, data, 4, 1, 0.580151, 0)
rpmId = addChannel("RPM", 25, 0, 0, 10000, 'RPM')
tpsId = addChannel("TPS", 10, 1, 0, 100, '%')
atsId = addChannel("ATS", 10, 1, 0, 200, 'C')
ctsId = addChannel("CTS", 10, 1, 0, 200, 'C')
fpsId = addChannel("FPS", 10, 1, 0, 200, 'PSI')
opsId = addChannel("OPS", 10, 1, 0, 200, 'PSI')
processCAN()
function processCAN()
repeat
local id, e, data = rxCAN(0)
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
function map_chan(cid, data, offset, len, mult, add)
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
