Link G4
The following script adapts the Link G4+ to RaceCapture/Pro
Notes: Uses the Generic Dash 2 profile.
Status: Needs verification
--This example configured for Link G4+ ECU
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 1
--params: <channel name>,<sample rate>, <logging precision>, <min value>, <max value>, <units label>
tempId = addChannel("EngineTemp", 1, 0, -50, 205, "C")
iatId = addChannel("IAT", 10, 0, -20, 205, "C")
oilTempId = addChannel("OilTemp", 1, 0, -20, 205, "F")
ignAdvId = addChannel("IgnTiming", 10, 0, -100, 100, "Deg")
wheelSpdId = addChannel("WheelSpeed", 10, 0, 0, 300, "kph")
oilPressId = addChannel("OilPress", 10, 0, 0, 1000, "kPa")
fuelPressId = addChannel("FuelPress", 10, 0, 0, 1000, "kPa")
lambda1 = addChannel("Lambda1", 10, 3, 0, 3, "")
lambda2 = addChannel("Lambda2", 10, 3, 0, 3, "")
steerId = addChannel("Steering", 10, 0, -360, 360)
baroId = addChannel("Baro", 1, 0, 0, 200, "kPa")
gearId = addChannel("Gear", 5, 0, 0, 6, "")
knockId = addChannel("Knock", 10, 0, 0, 1000, "")
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, data, <CAN offset>, <CAN length>, <multiplier>,
-- <adder>, [filter])
CAN_map = {
[1200] = function(data) map_chan(rpmId, data, 0, 2, 1, 0)
map_chan(tempId, data, 4, 1, 1, -50)
map_chan(iatId, data, 5, 1, 1, -50)
map_chan(oilTempId, data, 7, 1, 1, -50) end,
[1201] = function(data) map_chan(tpsId, data, 0, 2, 0.1, 0)
map_chan(ignAdvId, data, 2, 2, 0.1, -100)
map_chan(wheelSpdId, data, 4, 1, 0.1, 0)
map_chan(oilPressId, data, 5, 1, 0.1, 0)
map_chan(fuelPressId, data, 6, 1, 1, 0) end,
[1202] = function(data) map_chan(lambda1, data, 0, 2, 0.001, 0)
map_chan(lambda2, data, 2, 2, 0.001, 0)
map_chan(steerId, data, 4, 2, 0.1, -3000)
map_chan(baroId, data, 6, 2, 0.1, 0) end,
[1203] = function(data) map_chan(gearId, data, 0, 1, 1, 0)
map_chan(knockId, data, 6, 2, 5, 0) end
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
function map_chan_le(cid, data, offset, len, mult, add, filter)
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
local cv = value * mult + add
setChannel(cid, cv)
function map_chan_be(cid, data, offset, len, mult, add, filter)
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
