Megasquirt CAN
Channels enabled:
- Engine RPM (RPM)
- Throttle Position (TPS)
- Air/Fuel Ratio (AFR)
CAN Database
CAN Bus database for Megasquirt
Megasquirt Wiring
- CAN High: Pin 34
- CAN Low : Pin 33
Photos
--This example configured for Megasquirt Dashboard Mode
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
be_mode = 1
--addChannel(<name>, <sample rate>, [logging precision], [min], [max], [units label])
rpmId = addChannel("RPM", 10, 0, 0, 8000)
mapId = addChannel("MAP", 10, 0, 0, 105, "kPa")
cltId = addChannel("Coolant", 1, 0, 0, 250, "F")
afrId = addChannel("AFR", 10, 1, 0, 20)
CAN_map = {
[1512] = function(data) map_chan(mapId, data, 0, 2, 0.1, 0) map_chan(rpmId, data, 2, 2, 1, 0) map_chan(cltId, data, 4, 2, 0.1, 0) map_chan(tpsId, data, 6, 2, 0.1, 0, filter_tps) end,
[1514] = function(data) map_chan(afrId, data, 1, 1, 0.1, 0) end
processCAN(CAN_chan)
function filter_tps(value)
--filter out overflow
if value > 100 then value = 0 end
return value
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
local cv = value * mult + add
setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
