BMW E30 Guide
Revision as of 04:12, 11 November 2017 by Sbarton (talk | contribs) (Fuel Level)
BMW E30 (1982 to 1993)
Use the Black wire in the C101 plug feeding from the ECU to the instrument cluster.
RaceCapture/Pro timer configuration
  • Timer Mode: RPM
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
Map values in RCP: 4.3 = 0 2.28 = 50 0.55 = 100
Oil Pressure
