Honda B Series Guide
Revision as of 22:28, 22 June 2019 by Brentp (talk | contribs)
Honda vehicles with B Series engines
Use ECU Pin A13
  • RaceCapture/Pro Settings:
    • Timer Mode: RPM
    • Pulse per revolution: 2
    • Timer Speed: Medium
Fuel Level
Fuel Level - Yel/Blk wire. This wire runs from the fuel level sending unit to the gauge cluster.
  • If not using the gauge cluster
Disconnect the wire from the gauge cluster. You need to use a 47ohm pull-up resistor. The voltage range is 0.45 (full)- 3.5v (empty).
  • Channel settings
    • Sample Rate - 1hz
    • Smoothing - Max
    • Mapped
    • 0.45 - 100%
    • 3.5 - 0%
Oil Pressure
