AIM SmartyCam CAN
Revision as of 00:25, 15 April 2016 by Brentp (talk | contribs)
Connecting to the AIM system
BMW E46 (including M3)
Connection AIM Pin RaceCapture/Pro Pin
CAN High 1 2
CAN Low 4 3
Ground 2 1
Available Channels
This integration enables the following channels
RPM RPM
Gear Gear
WaterTemp EngineTemp
Oil Press OilPress
Oil Temp OilTemp
Throttle Position TPS
Head Temp HeadTemp
Exhaust Temp EGT
Brake Pos BrakePos
Clutch Pos Clutch
Brake Press Brake
Steer Position Steering
Lambda Lambda
FuelLevel FuelLevel
Integration Cable
Build your own
You can patch up your own cable using a Binder 5 pin series 702 patch cable and splice it with an RJ45 network cable.
Get a pre-made cable
AIM integration cables are available in our online store: AIM RCP integration cable.jpg Add to cart.png
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
CAN_map = {
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
